- Industrial Grade CO2 Measurement Range 0 – 2’000 ppm
- CO2 Measurement Accuracy ± (60 ppm + + 5% of reading)(25 °C, 400 – 2’000 ppm)
- Repeatability 10 ppm And Temperature stability
- NDIR measurement principle
- Temperature compensation of CO2 sensor signal
- Fully calibrated and linearized
- Superior long-term stability With Built-in reference channel
- Industrial Grade Sensor with 0 to 90% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.4% RH/0.1°C Accuracy 6% RH/ 0.8°C
- Encrypted Wireless Communications up to 2 Mile Range
- Send IoT Data to PCs, Amazon AWS, Microsoft Azure, and MQTT Servers
Introducing NCD’s Long Range Industrial IoT Wireless CO2 Temperature Humidity Sensor for Air Quality Monitoring with an integrated temperature humidity sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating CO2 temperature humidity sensors, this wireless IoT CO2 Temperature Humidity Sensor transmits highly accurate CO2 Concentration, temperature and humidity samples at user-defined intervals.
CMOSens® Technology for IR detection enables highly accurate carbon dioxide measurement at a competitive price. Along with the NDIR measurement technology for CO2 detection, a best-in-class humidity and temperature sensor is also integrated on the same sensor module. Ambient humidity and temperature can be outputted by Sensors’s algorithm expertise through modeling and compensating of external heat sources without the requirement for any additional components.
Thanks to the dual-channel principle for the measurement of carbon dioxide concentration, the sensor compensates for long-term drifts automatically by design. The very small module height allows easy integration into different applications.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 90% RH (non condensing). Powered by just 6 AA batteries and an operational lifetime of 300,00 wireless transmissions, a 5 years battery life can be expected depending on environmental conditions and the data transmission interval. An external power supply is supported by a special request.
With an open communication protocol, this IoT wireless CO2 Temperature Humidity Sensor for Air Quality Monitoring can be integrated with just about any control system or gateway. Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, Amazon AWS, Losant, and MQTT servers or to local Arduino processors for special handling. Sensor parameters and wireless transmission settings can be changed using an open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless CO2 Temperature Humidity Sensor for Air Quality Monitoring makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: Minimum data transmission interval is 30 seconds. This sensor is available with optional external power supply.
Recommended data transmission interval – 1hr
The Air vent filter will slow down the response time. In order to increase the response time, filter can be removed. Removing the filter will result into loss of IP65 rating.
Transmission Interval
This CO2 Temperature Humidity Sensor sends data periodically, based on user-preset timing intervals.
Wireless CO2 Sensor Applications
- In House Temperature Humidity Monitoring
- Hospital Air Quality Monitoring
- HVAC Applications
- Storage Unit Weather Monitoring System
- Warehouse Health Monitoring System
- Component of a Low Power IoT System
- Industrial Automation
- Wireless CO2 Temperature Humidity Sensor Monitoring for AWS® and Azure®
Sensor Probe Dimensions
- IoT CO2 Temperature Humidity Sensor for Air Quality Monitoring Product Manual
- Alpha Station – Sensor and Control Software for Windows using Visual Studio
- Long Range IoT Wireless Sensor FAQ
Community Repositories
Enterprise 868 MHz Sensors
Enterprise 900MHz Sensors
This device has been validated with NCD Micro Gateways.
900HP-S3B Wireless Compatibility Notes
Notice: Compatibility Notes Does NOT Apply to the Following Products:
- NCD Enterprise Solutions
- NCD Wireless Sensors
- NCD Enterprise Modems and Gateways
Notice: Compatibility Notes Applies to NCD Industrial Products, Including Fusion, ProXR, ProXR Lite, Taralist, and Reactor Series Products.
Compatibility Notes
When using an 900HP-S3B communication module, it is essential that you use the ZIGMO_PCB to configure the module settings. Long-Range wireless sensors may be programmed over the air without removing the communications module.
A 900HP-S3B Modem or a gateway of some kind that support the 900HP-S3B communications module will also be required.
